Won't try and talk you out of a good Tig welder as I talked myself into one late last year
Oh... Don't you worry, I need no encouragement, just (barely) sufficient (excuse) well researched justification (really just a good excuse) for diving into the welding side of things. I already had some of the TIG basic gear, and earlier today I hit a holiday sale at harbor freight to pick up most of the rest: heavy duty welding cart, baby starter welding table, basic magnets/clamps, and misc other stuff. Added a few MIG and stick specific items to the mix as well (not for my current project, but future use).
@mikerj: Good points. I already have most of the basics for TIG, including one of those tungsten grinder attachments for a dremel, from when I was messing around with a TIG machine at a local Maker's Space. The previous gas supplier I worked with for my oxy-propane torch charged full price for tanks but you just brought them in and swapped them and only pay for the gas, or just hang out for a bit while they refill the same bottle. I have since moved and haven't selected a new supplier so no sure yet what the locals offer.
@wizard69: Thanks for the tip on Swagelok, I'll check them out. My water cooling project is mostly about seeing if I can do it successfully when no off-the-shelf part exists or is ridiculously expensive (commercial CPU water blocks for narrow ILM server CPUs are about $120 to $200 per CPU socket per dual CPU server last time I priced them), and with the exception of one fried motherboard out of the stack of 4 servers, it has worked out more or less ok. All these machines are old retired enterprise servers and no one in their right mind would put in the massive effort (CAD, 3DP, fabrication, etc...) to water cool them unless it's a project, or like me, want my servers running very quietly next to my workbench instead of a sound-proofed closet far far away...
If these were newer servers or any consumer grade desktop with plenty of off the shelf solutions, I would definitely NOT go this route.
General FYI: I went with Aluminum literally because I could get 8mm square aluminum tubing on Amazon and didn't easily find available copper square tube around that size. Using square tubing because the flat sides are convenient for heat transfer from other flat things. True, connecting square metal tube directly to round silicone tubing is a PITA, but doable. Plus going the aluminum route is CHEAP at least for materials. Example, I built one heat exchanger that uses an Al plate as heat spreader brazed to the square tube, and this cools 2x Dual Ten gigabit ethernet chips (4x 10 GbE). I had to 3DP a bracket to mount the exchanger on the riser card that had no heat sink mounting holes since the original heat sink was epoxied onto the glass flip chips (PITA to remove). Total part cost was about $5.
Please feel free to suggest welding machines I should look at before I finalize my purchase... I'm currently looking at the Weldpro Omni 210, but there are other machines I'm considering... My budget is somewhat flexible depending on bang for buck, but I'm not buying any cheapo machines (<insert FIRE emoji here>). The Weldpro Omni 210 is about $1500, but I could probably go up or down if there is good reason. Miller Multimatic's are attractive, but I can't justify $4k. I messed with a Lincoln Electric Square Wave TIG, but I can't justify $2.4k for a machine that only does TIG... Etc...
Since I'm diving in the welding side and not just upgrading my lab/shop the absolute minimum for the project at hand, I want to make sure the welding machine(s) I get can handle multiple processes and all materials reasonably accessible to consumers, realistically for me would be mostly aluminum, but steel and possibly copper would make sense as well. I gave up trying to find a multiprocess machine that does AC/DC TIG, MIG + spool gun, stick, and Plasma cutting, (flux core as nice to have). They have machines that do just about every combination of those processes but they all lack at least one. For example, there are multiple makes and models that do all of the above processes including plasma cutting but only can do DC TIG not AC... It's irritating AF to find a bunch of machines that ARE SO CLOSE to a complete multi process machine but stop short. So, I'll get a plasma cutter separately as a future fun purchase (with distinct urge to pair with CNC table) and continue looking for a single ACDC TIG / MIG + spoolgun /stick multiprocess machine that performs decently all the way down at 5 - 25 Amp AC TIG for very thin aluminum (<= 1mm), ideally with pulse and some of the more interesting waveform manipulation features that might be useful for really thin aluminum. But still beefy enough for normal material thicknesses so the investment is still useful for other projects already bouncing around the back of my head.
Sorry about long post, I'm a little amped up about being so close to buying a whole new genre of toys (horrible pun intended)... heh.
