What is your preferred method for connecting two boards together?
Generally speaking, I'm a Male to Female pin headers board to board stacker kind of guy, so I'm always a little surprised to see flat flex inside products when they are simply rigidly mating two PCBs together inside some assembly.
I get that flat flex makes it possible to flip the boards apart and probe the bottom side, but that doesn't seem like a good "design for production" kind of decision since its much easier to just plug one board into the other on the assembly line when you start cranking out volume. Make the RMA department a cable fixture for testing, and that problem mostly goes away.
What mating situations really benefit from flat flex? Specifically here I'm talking about two boards rigidly mounted together, not like an LCD board that is remoted, or two boards that actually need to be able to move independently like a adjustable keypad or something.
Thoughts?
