Author Topic: AoE photodiode boostrap  (Read 957 times)
Offline nihialTopic starter
« on: July 29, 2020, 05:18:44 pm »
In the AoE in the photodiode section there's a circuit where a photodiode is bootstrapped by a jfet. It is mention in the text that there is a emitter follower not shown for simplicity but I don't understand where you put it. I'm trying to upgrade a frontend of a photodiode stage I'd like to test the circuit with that mentioned emitter follower especially if it improves the overall circuit.
Thanks in advance !
Offline PartialDischarge
Re: AoE photodiode boostrap
« Reply #1 on: July 29, 2020, 05:39:55 pm »
Turn to the next page and there you have your emitter follower in 8.83!
The following users thanked this post: nihial
Online David Hess
  • DavidH
« Reply #2 on: July 30, 2020, 02:23:05 am »
Adding an emitter follower in series with the source of an FET is done because the transconductance of the FET is so much lower.
« Reply #3 on: July 30, 2020, 06:59:28 pm »
Oh my god I feel so dumb to not have seen it
« Reply #4 on: July 30, 2020, 07:00:19 pm »
Thank you for the explanation
Online David Hess
  • DavidH
« Reply #5 on: July 31, 2020, 01:53:10 am »
I should have also said that it is very common circuit configuration when you want an FET source follower to have a gain close to 1 and the ability to drive any significant load resistance.  The impedance buffer for oscilloscope inputs and active probes almost always uses the same configuration.
An alternative with better performance at low frequencies is the FET equivalent of a Sziklai pair with the input transistor replaced with an FET.  Local feedback keeps the gain closer to 1:
https://en.wikipedia.org/wiki/Complementary_feedback_pair
