You are solving an imaginary problem.
This specific application is powered by an upstream buck that has a very precise power limit. If I exceed this power limit, the upstream buck will shutdown for a period and reset. I have no control over this, so I have to design my buck to play by its rules. This is – at least, in my mind – the reason that I need to soft start: charging that much output capacitance is going to cause me to exceed my power limit. Is this assumption somehow incorrect?
Yeah I haven't seen more than 220uF bulk capacitance on the output of a switching regulator. I'd question if 1mF were really necessary.
Yeah, I would love if it weren't. I may try to get around it by distributing bulk capacitance along the output rail behind inrush-controlled load switches.
On soft start: I don’t remember seeing ‘soft start too slow’ in buck controller data sheets. Maybe you could experiment?
Sadly, this was relayed to me by TI's engineers as their concern. So I guess it's something they just don't consider relevant enough to put in their datasheets. 😂
Hmm. Perhaps a dumb question: could you throw out the buck converter and run your Class D amp straight off the original power supply?
Not a dumb question! I have a wide V_in range that's roughly double my output voltage. The Class D amp operates *very* efficiently and with minimal THD at this output voltage – which is why I chose it as the primary rail voltage. Unfortunately (as you see elsewhere in this post) there's a buck upstream of this one that is *very* tightly power-limited, with a circuit-breaker behavior. If I exceed the power limit, I get shut off. Not my choice, and out of my control.
Traditional linear audio amplifiers are known for liking great big DC caps because they need to ride though the nulls in the incoming AC power. Have you experimented with different sizes of cap to see what’s necessary for you? And if the sound quality is impaired, do you know how/why?
I don't have a lot of room to experiment with this one; the datasheet of my amp does a lot of heavy lifting, since it clearly specifies max ripple, its effect on THD, etc. From the perspective of my device, I've got a DC power source.
I haven’t worked with Class D before, but I imagine 2 things to look out for are “the DC rail dips too much for bass”, “the switching noise from the buck makes undesirable tones in the outputs.”
If it’s the latter, have you looked into synchronising the buck converter and Class D amplifier switching frequency? This can (as I understand it) help you place weird frequency mixing products outside the audible range.
I suspect you're right re: DC rail dipping for too much bass. Luckily, my Class-D will change its equalization on the fly if it detects that its supply rail is browning out, but the overall goal of sound quality is compromised in this case – which is also something to avoid. I'm sizing for 1.5x RMS current.
