Author Topic: Anyone else building an analogue synthesizer here?  (Read 13338 times)
Offline LektroiDTopic starter
  • If it didn't explode, I'm happy.
    • Music here
« on: September 04, 2014, 07:13:37 am »
I've been building this behemoth for the past few years, I just wondered if there's any other synth buffs on here?
Online T3sl4co1l
    • Seven Transistor Labs
Re: Anyone else building an analogue synthesizer here?
« Reply #1 on: September 04, 2014, 07:36:11 am »
Um, technically, on a far more humble scale; my Theremin is always evolving, and currently uses about 50 transistors (no ICs*).
By building, do you mean buying modules, or...actually building every freaking one of those things?!
Seven Transistor Labs, LLC
    • Music here
« Reply #2 on: September 04, 2014, 07:53:33 am »
Awesome! I cheated and bought a Moog Theremin Plus, mainly for the CV outs to control the modular. I would love to build my own though. Did you design it yourself?
I made a point of not buying any production modules...
Built myself, mostly through hole, but a few SMD's here and there. Some boards are home etched, others were blank manufactured double sided PCBs. The panels in the top (5U) section are all home drilled and handwritten, in the lower (3U) section, they are factory printed. There's a few interesting parts inside, like vactrol opto's for nice bouncy CV control & tempco's to stabilise the oscillators. Not all discrete components like your Theremin though, there's quite a few CMOS chips & op-amps lurking inside...
Online T3sl4co1l
« Reply #3 on: September 04, 2014, 09:21:03 am »
Yes.  This documents the basic build:
http://seventransistorlabs.com/Theremin/
I built a few of those, with minor changes between them.  The most developed of which I keep on hand, and modify periodically.
Right now, it includes:
- Discrete transistors (approx. 50 total, mostly 2N3904 and 2N3906)
- Pitch, Volume, and Local Oscillators: Hartley, ~2MHz, Buffered, Adjustable (via varactors)
- Pitch and Volume Mixers: single balanced (single ended output coupling)
- Level Control Mixer: single balanced (balanced current mirror output coupling)
- Volume IF ~10kHz; slope detector
- Riser board: all important signals and control voltages are available on an expansion connector
- Audio output: max. 0.1W power amplifier, 1/4" phono jack output
- Power supply: 9V wall wart (primary source), onboard converter supplying regulated 6.3 and 120V DC (9 transistors, discrete except for the TL431, an acceptable sacrifice)
Currently, the riser board includes a timbre circuit (primarily a single common-emitter amplifier stage with variable input and bias levels to vary distortion and clipping), and a PLL which implements an auto-tune-and-hold feature, allowing instantaneous adjustment (no fiddling with trimmer capacitors or antenna position!).
Future plans: the switching converter was designed to provide the perfect voltages for vacuum tubes, with enough current capacity to power one or two 9-pin miniature types.  These will be added to a new riser board, or a second level stacked on top, to provide "That Tube Sound".  It should also be possible to add a PLL to the volume control section, for automatic tuning of that section as well.
(this was mostly copy-and-pasted from another document)
The PLL I don't think I've heard mention of before, which is odd because tuning these things is a bitch.  Any slight change in the environment (imagine setting it up on a metal music stand or something) or temperature (I haven't matched tempcos yet, so it drifts quite a bit) makes for a lot of tedious adjustment.
The circuit, I've posted before:
The mixer output (as mentioned above) has a DC coupled resistive load, so when the beat is zero frequency, it's zero as in DC, so it's a fine phase detector.  Comparing that with a fixed threshold (depends on mixer bias, but since that's set with resistor dividers, a fixed resistor divider should be fine here as well) gets a phase error signal, which goes right into the pitch oscillator's varactor.  The only funny part about this, I think, is the amp itself serves as the sample-and-hold: the 2N3904/6s have low enough leakage (and the MOSFET follower, basically none), that the 0.01uF compensation capacitor stays quite nicely at whatever operating point it stabilized to.  No need for suboptimal building blocks (namely, an op-amp, analog switch and JFET op-amp follower), which would consume loads more current (not that power is in short supply here) and suffer from capture transient problems (while disconnected, an always-on error amp will wander off into la-la land and saturate, guaranteeing a worst-case frequency spike every time the analog switch is closed -- it might not even re-lock phase anymore).
An insane amount of work for a few years, in my opinion!  I'm not very musically obsessed though, which would surely count for a lot.
Doing stuff like OTAs, S&H, VCOs, timers -- not terrible to do discrete, but for the most part, yeah, even I would be piling the chips on, no problem there. ;)  Add in things like switched capacitor filters, sequencers, muxes and so forth, and you're counting a lot of CMOS alone, that would've been just a royal pain back in the day (early 60s or earlier, I guess?).
Offline German_EE
« Reply #4 on: September 04, 2014, 03:20:50 pm »
Not now but in the 1980's I built my own version of the Mini Moog. The keyboard drove some logic that let me generate three note chords with one VCO per note. I managed to cure every problem apart from drift which meant that I gave up in the end.
If I was building a synth now I would make it all digital. A memory mapped keyboard driving DDS based oscillators takes care of sound generation and a DSP can do the work of the filter and envelope generation stages.
Warren Buffett
Offline DenzilPenberthy
« Reply #5 on: September 04, 2014, 03:32:37 pm »
Wow, that is a very impressive project! I built one of these from a kit a long time ago.
http://www.paia.com/fatman.asp
Before too long I realised I had a lot more talent with electronics than music!  :)
    • Music here
« Reply #6 on: September 04, 2014, 03:41:58 pm »
There's a few digital modules in my build, but not filters, filters always sound better in the analogue domain. That's the only thing I would not cut corners on, if I were to build a digital synth :)
Offline Len
« Reply #7 on: September 04, 2014, 04:17:06 pm »
If you fixed the drift it wouldn't be a Mini Moog any more!
DIY Eurorack Synth: https://lenp.net/synth/
Offline RobertoLG
  • Country: br
« Reply #8 on: September 04, 2014, 04:28:59 pm »
not exactly on topic but related, you may like it, enjoy :D
http://youtu.be/69Wjc6QYuKI
and these guys too: http://youtu.be/vSg2pfn-T7g
« Last Edit: September 04, 2014, 04:58:55 pm by RobertoLG »
Offline electrophiliate
  • Eternal Novice
« Reply #9 on: September 06, 2014, 02:37:32 am »
@ LektroiD. Cool project. A friend of mine used to be really into analogue synthesizers but has since moved onto Native Instrument's Reaktor software for the PC. After having a go at some classic equipment like the Roland 101 synthesizer I wondered about building individual hardware modules but never really got into it. Good to see that other people are into it though!
Nothing is quite like a great humming power-station.
Offline Alex30
« Reply #10 on: September 06, 2014, 02:21:37 pm »
Wow this is impressive, would love to hear any music you have produced with this bad boy
Offline Yago
« Reply #11 on: September 06, 2014, 03:30:07 pm »
That is a synth indeed!
I too would like to hear some sonic rippage from that beast.
    • Music here
« Reply #12 on: October 30, 2014, 03:29:20 pm »
Thanks for the comments, I generally use all my hardware to make music (not just the DIY stuff). Here's my latest effort, I use the big synth for various percussion and bass, clocked through MIDI from the computer, meaning I can keep the other instruments clocked from the same source.
For the more refined stuff, check out the link in my signature...
Offline dentaku
« Reply #13 on: October 30, 2014, 04:52:49 pm »
Synths are pretty much the reason why I have any interest in electronic hardware.
When I first started looking into how synths work I found it interesting how all the terms we use in synth programming even today with VSTs turn out to come from the early days of electronics. I like that synth manufacturers didn't try to rename everything to make them more musical sounding.
I find analogue sound sources to be interesting but not really practical allot of the time but I do believe that filters are still best left analogue.
Lately I've been looking into exponential converters and I'd love to find a very simple VCO/Expo converter combination that is good for experimenting with on breadboards just as a learning experience.
The best thing I've built lately is the Hip Bass Drum by Craig Anderton.
http://electro-music.com/wiki/pmwiki.php?n=Schematics.HipBassDrumByCraigAnderton
The next step would be to build a step sequencer with maybe some 4000 series counters and multiplexers or maybe a shift register of some sort.
Offline Yago
« Reply #14 on: October 30, 2014, 05:13:35 pm »
Tried a listen of your track, and could hear nothing from the massive 1inch computer speaker... intro in the bass I guess!
Looks like I'll have to finish repairs on soundcard to hear it properly, argg inspired into work by EEVBlog again!
I always thought keys are another of life's nodes that attracts geeks, or turns the geek upon them!
Have always been a geek really, played keys and piano for decades now, but some years in a band kind half turned me back towards the normal side. Like Blade, a halfbreed of normal and geek, (a nork? :p).
Still have digital electric piano and Korg T3, and that old guitar amp I should repair (eek valves!).
Will tune in to your threads more Lektoid, if my feeble memory holds out! :)
Offline Kjelt
« Reply #15 on: October 30, 2014, 09:47:05 pm »
Very impressive. I love the analogue synth sounds but would not know where to start building one. Friend of mine had a yamaha cs80 he had to tune each few hours and change some cmos chips twice a year, not very practical. Loved the sound though but unable to build it due to the custom asics  :(
Will you show some schematics and explanations?
Offline RobertoLG
  • Country: br
« Reply #16 on: October 30, 2014, 10:11:03 pm »
heh, do you like Vomito Negro???
http://youtu.be/o6009QG4XNk
http://youtu.be/rvnA6lwdeg4
http://youtu.be/UZjbAA1GCzk
cool stuff :)
« Last Edit: October 30, 2014, 10:12:45 pm by RobertoLG »
Offline MasterBuilder
« Reply #17 on: October 30, 2014, 11:01:11 pm »
Very nice big modular you have.
Im currently building a few modular bits, my plan is to include:
Mutable Instruments Anushri
A montoron delay in modular format
A Meeblip in modular format
DIY mixer, power supplies and Midid thru
This is a great resource for inspiration for DIY modular:
http://cgs.synth.net/
Offline Yago
« Reply #18 on: October 30, 2014, 11:14:12 pm »
Aha, I had a listen to "Darktones", nice :) (and my sound card works yet again!)
Much prefer electronic to be a little slower, go for the swing/groove before tempo anyday. ( too old to dance and 1988 is just corrupted data now:P )
A bit of influence from Planet Rock and Tour De France in there, will listen to some more I think :) .
Offline miguelvp
« Reply #19 on: October 31, 2014, 06:20:56 am »
This was posted on another thread a while back:
http://www.ucapps.de/
I'm not into this but my son is, that's why I kept the link.
Offline 22swg
« Reply #20 on: October 31, 2014, 09:24:31 am »
Lecktroid... Just to say , great work  where is the keyboard  ;)
 Edit    Um   I watched the vid...  :palm:
« Last Edit: October 31, 2014, 12:11:54 pm by 22swg »
Check your tongue, your belly and your lust. Better to enjoy someone else’s madness.
Offline dentaku
« Reply #21 on: October 31, 2014, 11:58:19 am »
Olivier Gilet from Mutable Instruments would be a good guest for Chris and Dave to have on The Amp Hour sometime when he has time. He's quite busy right now trying to fill orders and finish new projects.
    • Music here
« Reply #22 on: November 02, 2014, 12:00:19 pm »
How about this one?
Offline calexanian
    • Alex-Tronix
« Reply #23 on: November 02, 2014, 10:20:54 pm »
Very nice. I have played with building envelope circuits and just straight analog keyboards, but never that large. I have always had some kind of small do everything keyboard around to fill my need for bleeps and farts. I also have an Arp Omni 2 that is at a friends studio. Once I got that all feeling of need to build a synth went away, and every year I visit with Eric Barbor from Metasonix and get my analog synth jargin fix.
Charles Alexanian
Alex-Tronix Control Systems
Offline Yago
« Reply #24 on: November 04, 2014, 10:21:39 am »
How about this one?
Nice!
Quite a few different "textures" mixing in there that normally don't sit together.
No soon as it starts, it goes through JMJ, The Who, several others and finally settling on something akin to old OMD with an updated sound!
Electronica is not really my "go to" music (to rip a USA "tool time" expression :P), but you certainly have talent and write nice material.
I am half tempted to start plugging some stuff together... must fight the urge, have to finish the lab first...
