Author Topic: any one know such RFID reader?  (Read 889 times)
Offline alireza7Topic starter
« on: March 02, 2018, 08:23:47 pm »
hi
do you know such RFID reader that have these specs ?
iso 14443 / iso7816
mifare desfire card
sam slot
-40 to 85 celsius degree   (or at least  0 to 50)
having interface appropriate for connecting to a micro controller (not just compatible with windows , Linux , ...)
« Last Edit: March 02, 2018, 09:05:38 pm by alireza7 »
Offline dgtl
  • Country: ee
Re: any one know such RFID reader?
« Reply #1 on: March 02, 2018, 08:49:05 pm »
There are such RFiD reader IC's, that you connect via SPI to your uc; most of the work is done in this one ic and you need some passives and an antenna. For example, NXP has PN7xxx and CLRC663 series; ST has some and some others as well. The manufacturers provide software libraries to talk to most common tags without too much work. You can copypaste the evaluation board pcb layout for easier hw development. If you are not developing your own board, some vendors (ie sparkfun) sell arduino-like modules etc.
When designing your own board, the antenna tuning is a tricky thing to get right (there are some capacitors, inductors and resistors for matching the on-board antenna to the chip). With simple tools and some trial and error, you can get decent tuning (ie 3/4 read range of the best possible); for very good tuning, it takes a lot of specialized tools and know-how. Also, the enclosure and all nearby metals to the antenna affect the tuning, so going with an existing reader may even force you to re-tune the antenna matching circuit it read range is important for you.
« Reply #2 on: March 02, 2018, 09:15:36 pm »
the thing  that i didn't mention is that i also need my rfid reader have SAM slot (secure access module) .
can you explain me what is sam exactly ? can i design it's slot on my board?
i was looking forward to such complete modules : acr1252u
https://www.acs.com.hk/en/products/342/acr1252u-usb-nfc-reader-iii-nfc-forum-certified-reader/
i may consider designing my own rfid reader but using a stock module is in Priority
« Last Edit: March 02, 2018, 09:18:09 pm by alireza7 »
« Reply #3 on: March 03, 2018, 11:36:36 am »
also i found this module : DE-ABCM_TB
http://www.duali.com/eng/nfc-product/nfc-module/built-in-antenna-module.html
it seems a good  module , do you have any idea about it? or do you have any suggestion?
