Yes I do.
The latest 'bugfix' for this version involves replacing all of the p-ch mosfets and accompanying zener diode with a single beefy schottky diode (like MBR1045, TO-220 + heatsink). It is a bit of a hack, but works quite well.
MBR1645 Schottky diodeThe free-standing TO-220 should get some more support though. It's heatsink could be epoxied to the big heatsink, as they're the same potential anyway.
The voltage drop across the Schottky diode is only 0.35V at 1A and doesn't go above 0.5V for 5A, so the dummy load does work down to low input voltages.
If you can wait a bit, I've just ordered the next revision of this project and there will be a small number of DIY kits + a couple of bare pcbs as well. The next revision will have all TO-220s mounted to the big heatsink and will allow very basic remote control with 0-5V signals. I it works...
The bare pcb of the current version is 5.50€ + shipping. In case you also need the heatsink (alutronic 'V PR127/94-M3') + clips (may be a bit hard to find), let me know and I'll add it to my next order (probably tomorrow). That would be an extra 2.77€ for that.
