That's a really bad design, as other earthing boxes use the same connections to earth the ESD mats via a 1Mohm resistor.
Best not to mix up different practices.
It would also fail a Production Quality Assessment,
Before you enter a static safe area, both the wrist strap and wrist cable, as well as a heel strap must be checked for continuity.
by leaving the wrist cable at your bench then you are not performing this check.
Most people just remove the entire thing and leave it in their coat pocket, never seen anyone try to unsnap one before, that's asking for a broken cable.
