I am using a DAC PCM5102APWR whose output I am feeding to a TDA2050 amplifier. There is a lot of noise when i connect them directly. So, I am using a 1:1 Audio Isolator DA103MC in between them. The audio output is now with out noise but the sound quality is not good when i operate the system at high volume. I think the output is being clipped. I want the audio output to be less distorted. So, what should i do?
I have designed my circuit according to the reference design in data sheet. The TDA2050 is powered by single supply of 12V.
