Author Topic: Looking for a replacement for this capacitor  (Read 1860 times)
Offline TectonicTopic starter
« on: January 17, 2014, 05:42:33 pm »
The pictures are from the power module of an Agilent 6622A power supply. I want to replace the capacitor but I'm not certain what part I should order from mouser/digikey. The Agilent part number is 5060-3218. I haven't found a cross reference of the manufacturer's model # for this.
Any idea what I could use to replace it?
Offline Monkeh
Re: Looking for a replacement for this capacitor
« Reply #1 on: January 17, 2014, 05:44:00 pm »
Why do you want to replace it?
« Reply #2 on: January 17, 2014, 05:51:41 pm »
The unit won't power up and I suspect a bad capacitor. I haven't yanked it out yet but I'm getting ESR measurements that fluctuate between 4 and 80 ohms for this capacitor. It's possible there are two more blown capacitors on that module.
Offline Monkeh
« Reply #3 on: January 17, 2014, 05:53:15 pm »
Yank it and test it. Be aware that there is a resistor across it in circuit.. These caps rarely fail in any manner other than explosively or open circuit, and shouldn't affect operation anyway.
Offline Greg Robinson
« Reply #4 on: January 17, 2014, 06:02:11 pm »
« Reply #5 on: January 17, 2014, 06:12:23 pm »
There are two more capacitors. These come up as 328 ohms each on my meter.
Offline Monkeh
« Reply #6 on: January 17, 2014, 06:15:18 pm »
They're RFI suppression caps. They really have no functional impact on the power supply.
« Reply #7 on: January 17, 2014, 06:21:23 pm »
Thanks for the info. I'll probe around some more and see if I can find out why it won't power up.
