Author Topic: Analogmax-daq1 and daq2  (Read 1047 times)
Offline cncjerryTopic starter
« on: January 15, 2020, 01:50:55 pm »
Anyone try out one of these yet?  It is offered by ADI, contains the following including an 18bit, 2msps ADC and an intel FPGA.  Price is around $170usd.  There is example software for data acquisition written in python and I think there is a data analysis package. Looks pretty cool for the hobbyist.
https://www.arrow.com/en/products/analogmax-daq1/trenz-electronic-gmbh
Features:
- Intel® MAX 10 Commercial [10M08SAU169C8G]
       - Package: UBGA-169
       - Speed Grade: C8 (Slowest)
       - Temperature: 0°C to 85°C
       - Package compatible device 10M02...10M16 as assembly variant on request possible
- SDRAM Memory up to 64Mb, 166MHz
- Dual High-Speed USB to Multipurpose UART/FIFO IC
- 64 Mb Quad SPI Flash
- 4Kb EEPROM Memory
- 8x User LED
- Micro USB2 Receptacle 90
- 18 Bit 2MSPS Analog to Digital Converter
- 2x SMA Female Connector
- I/O interface: 23x GPIO
- Power Supply:
       - 5V
- Dimension: 86.5mm x 25mm
- Others:
       - Instrumentation Amplifier
       - Differential Amplifier
       - Operational Amplifier
I'm probably going to grab one and see if I can use it for time-nut stuff.  Having those 2 sma connectors, though I think they are differentially, implemented looks interesting. Maybe I can use it as a TIC.
Jerry
