Thank you for the response!
Looks like I was pretty off. To be honest, for the LED I used digikeys "LED Series Resistor Calculator" here:
https://www.digikey.com/en/resources/conversion-calculators/conversion-calculator-led-series-resistorAlthough now that I look at it again, its telling me I am indeed way off. Especially considering we're targeting 4mA max output for the flip flop.
As for the transistor current biasing, this was a left over value from a previous project. Where I did in fact (mis)calculate the resistor at about 1K, but the motor refused to fire until I put in this much smaller one...
But that certainly explains some of the behavior I have been seeing! I will make the appropriate changes to the transistor and the LED circuit and report back.
I sometimes work from home and some of these projects drag out so long I often forget what design work I've done and what I haven't!
As for the DRV2603, the board I am testing it on does not have the transistor nor the LED populated. So the current supply should not be slammed trying to source those components.
Looking at the data sheet for the DRV2603 it says it only needs a couple of micro-amps to trigger the LED input. So I am not sure what I am doing wrong.
The datasheet is also pretty lax on describing the device orientation (index pin). I did find a small dot on the package and assumed that was the pin 1 index. However, doing this a couple times shorted the circuit each time. Its a small footprint and maybe I just soldered it wrong a couple time in a row? But there definitely weren't any solder jumps between pads...
Looking at the component pins with a jewelers loop reveals all of the pins have about the same shape, so thats not really helpful.
Thanks again and let me know what you think!
Cheers!
Brett
