I can't get the download to work - got a 'Fatal Error - Unable to find "dwf.dll"'. What am I doing wrong? My PC in Win 7 x64, .Net 4.6.
Thanks.
Had the same problem. I've reported it to jaxbird but he seems to be away
In the interim this work around got me going
Download and install the old version of waveforms from here
http://store.digilentinc.com/waveforms-download-only/Select "downgrade" for all the options
This should be enough to get his program working.
If you want/need the new Waveforms2015 version as well as his software then continue with the following
With the old version now installed go to C:\windows\SysWOW64 and copy dwf.dll from this directory
Then go to C:\Users\<your user name>\AppData\Local\Apps\2.0\MZKGDAT1.PHM\N5YL8OR9.1AQ\audi..tion_0000000000000000_0001.0000_e5f4f61c851d23cd directory
At a guess some of those alphanumeric directories may be different in you installation. You need to find the folder containing these files-
Audio-Frequency-Icon.ico
AudioAnalyzerSuite.cdf-ms
AudioAnalyzerSuite.exe
AudioAnalyzerSuite.exe.cdf-ms
AudioAnalyzerSuite.exe.config
AudioAnalyzerSuite.exe.manifest
AudioAnalyzerSuite.manifest
Paste the copied dwf.dll here
You can now re-install the new version of waveforms(2015) and AudioAnalyzerSuite will use the DLL in its local directory first. allowing you to use his software and the new version of waveforms
