Looking forward to the release of this software jaxbird. Then I'll get an AD.
Excellent work.
Hey, how hard is it to do a "normalize"... i.e. the software takes a base reading, normalize it to flat response, then put the DUT, and let the software do it's thing (relative to the normalized base reading)?
Thanks, but you should only invest in the Analog Discovery if you really feel you have a use for it, no obligations
I'm putting a lid on new features until a release is available, after that I'll start tracking bugs and feature requests.
I've been preparing the software for distribution, primarily to make it easy to distribute and update, so I've gone with a web deployment strategy with update check on startup. It will still run fine offline, but if online and there is a new version available on startup it will suggest to update. Not that I expect it to be full of bugs, but I'm sure there will be many updates initially so easy updating is fairly high priority.
Also it needs a bit of explanation on how to configure connections for the various measurements, some measurements require various shunt resistors. So I'm compiling a document for reference and perhaps a video.
Anyway, I expect to have an install ready within the next couple of days.
