Author Topic: An unknown/missing ic needs replacing  (Read 1327 times)
Offline K-ExperimentTopic starter
« on: October 04, 2019, 05:44:19 am »
I want to make my own soldering station and i was thinking of creating a hakko 936.
but there is one ic that i couldnt buy from lcsc so can you help me?
 the ic is a low power quad op amp: Nec uPC324
and if i may ask, how much current does it need from the transformer? is it 2.5A?
« Last Edit: October 04, 2019, 05:51:30 am by K-Experiment »
Offline oPossum
Re: An unknown/missing ic needs replacing
« Reply #1 on: October 04, 2019, 05:49:05 am »
« Reply #2 on: October 04, 2019, 06:13:05 am »
sorry im still new to electronics and im quite bad at reading datasheets but
are you sure its an exact replacement?
Offline ledtester
« Reply #3 on: October 04, 2019, 03:42:28 pm »
It's the same "324" op-amp. TI uses an "LM" prefix whereas NEC uses "uPC" to identify its parts.
Attached are the datasheets. Note that the schematic diagrams are identical save a current source of 4uA in the TI diagram which has a value of 6uA in the NEC version.
I bet the uPC324 was the chip the author found on his board when reverse engineering it, but they wrote "LM324" next to all of the op-amps to indicate than any 324 op-amp would work.
« Last Edit: October 04, 2019, 03:51:12 pm by ledtester »
The following users thanked this post: K-Experiment
Offline amyk
« Reply #4 on: October 04, 2019, 07:38:45 pm »
The uPC1701C is going to be the hardest part to get if you want to make a "true" 936 clone.
All the clones available use something simpler and cheaper instead, but some of them are designed for thermocouple sensors; here's one that uses the original thermistor type sensor: https://ai.esmplus.com/jnkgloballtd/solderingstation/lm358_simple.png
Offline ledtester
« Reply #5 on: October 04, 2019, 08:03:03 pm »
« Reply #6 on: October 05, 2019, 12:40:04 pm »
so the uPC1701 can be replaced with a UAA2016?
