The datasheet gives the maximum value for 1N5817,18,19. Fv-0.32,0.33,0.34v. The real value, as we can see, can differ significantly.
It may differ, but assuming equal test current and temperature (and equally working part) it should not be that different.
Differences in handling current, leakage, maximum reverse voltage, forward voltage drop, size, power dissipation (correlated to size) etc.
In case you have doubts about the quality of the new parts you probably have to do some tests under load - measure Vf at 1A and check for allowed dissipation. You can also check the Vr-reverse-breakdown voltage with a voltage source limited to e.g. 0.5mA. It´s a little more effort to check recovery time.
I measured about one third of that difference with a set of 9 1N5819s, but they were likely all from the same order, so 60 millivolts would not surprise me at all between two different batches or two different manufacturers.
Quote from: David Hess on July 31, 2024, 02:20:18 pmI measured about one third of that difference with a set of 9 1N5819s, but they were likely all from the same order, so 60 millivolts would not surprise me at all between two different batches or two different manufacturers.At what current did you make your measurements?
