HI aargee,
Funny that you mentioned this, as it is another project on both my bench and list of thing's to finish.
Not so much as a PCB/ribbon style device but " dummy " batteries that I have made out of PTFE and Delrin with a brass centre conductor.
I have already made a few in CR123a size for my Cree torches, they came with 18650 batteries but I have a stack of CR123A's that I want to use up, so I made spacer dummy batteries on the lathe. I now want to finish the AA AAA C D sizes for general testing with removable flying leads and my variable power supply for a variety of devices.
And for those that may have concern's, the torches are brighter with the 18650's, but I have other evil plans for these batteries.
I end up with lot's of slightly used CR123A's from the type of work that I do and have been putting them to good use in other gadget's.
I can knock these up in very little time at all, material is at hand, I'm just pondering over the best method for the lead connection, I may just internally thread the brass rod on a couple for attachment .
Muttley
