Author Topic: IC for voice command  (Read 2924 times)
Offline Tricka90Topic starter
« on: October 31, 2014, 08:10:16 am »
Some years ago I found an IC for voice commands but I can't find it anymore.
It worked this way: first you record an audio sample, like a secret word, and the IC will save it on his memory. Then the IC will recognize the secret word every time you pronunce it because it will compare the audio samples.
Can you guess the IC name?
Offline bktemp
Re: IC for voice command
« Reply #1 on: October 31, 2014, 09:23:55 am »
