Author Topic: bench PSU 0-->15V 0-->3A  (Read 267 times)
Offline Ahmed_MKTopic starter
  • Country: eg
    • no website
« on: June 26, 2024, 04:45:03 pm »
I watched a couple of videos on lab power supplies by Dave and I tried to attempt to make my own.
*check attached image
I am a beginner and It is my first electronics project.
I have not finalized it.
However, I have a couple of questions on OP-AMPS and On the way I attempted to get negative voltage.
    1. In the data sheet for the op-amps it says  "All voltage values, except differential voltages, are with respect to the midpoint between VCC + and VCC −"
        and it says Vcc =( + or - ) 18V.
        does that mean I could put +28.6V volts and -1.4V such that the range is less than 36V?
        *I would do that since the opamps used are not rail to rail
    2. Also, Proteus fails to simulate this circuit, it says too many iterations.
Furthermore, I would appreciate any advice you can give me?
Appreciated
Offline mikerj
Re: bench PSU 0-->15V 0-->3A
« Reply #1 on: June 26, 2024, 06:30:46 pm »
Yes, the supply rails do not have to be balanced.  Having a small negative voltage rail is reasonably common to allow the output of the op-amp to swing down to a true 0v.
I have no idea about Proteus though I've never used it, sorry.
The following users thanked this post: Ahmed_MK
Offline Benta
« Reply #2 on: June 26, 2024, 11:05:56 pm »
Why not just use a TI LM350K?
You'll need a negative bias voltage to get it down to 0 V output, but that's a nice little exercise. :)
To generate a negative supply voltage, this little circuit is great. You just need to make sure that the main (positive) supply line pulls more current than the negative.
« Last Edit: June 27, 2024, 12:47:21 am by Benta »
