Hi experts.
I need a group of colour changing, controllable LED's to be controlled by an App.
Each needs to flash, cycle, change or stay different or the same colours, individually or as a group.
https://www.aliexpress.com/item/1005006760854123.html?spm=a2g0o.cart.0.0.346a38daJgpcqe&mp=1The 5050 seems like the one i need as I have them in my pc lighting.
I think i need a LED controller but cant find one small enough?
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
A Bluetooth module
https://www.aliexpress.com/item/1005007053264830.html?spm=a2g0o.cart.0.0.346a38daJgpcqe&mp=1A rechargeable battery to last as long as possible and to be as small as possible
Everything needs to be as tiny as possible as they need to fit into well under 10mm sq and be as thin as possible.
Then i need to the PCB. i think?
Then i need the App to control the whole thing but at the moment i need to know if these parts would do what i need and whether i need anything else.
I have loads of other questions, such as do i need a controller or will the app be the controller? and how do i build a tiny PCB but they can wait till i know if the parts i think i need will work.
Both BTooth mod and LED are 5 Volt
As you can tell i am a novice but am hungry for advise.
Thanks
