Author Topic: DIY dual power supply  (Read 922 times)
Offline DhanushkaTopic starter
  • Country: lk
« on: June 08, 2019, 02:24:45 pm »
I am going to make a dual power supply using two 12 V/5 A power supplies and two buck boost converters (at least 2 V-30 V / 5 A with current limiting capability) connecting together. Please tell about this attempt under following things.
1. How will be the regulation comparing a cheap Chinese adjustable bench power supply (30 V/ 5 A) according to your experience with buck boost converters.
2. Safety of the 12 V power supplies. (I think that the are isolated enough to prevent electric shock when sudden loosing of the ground connection)
3. Noise for the experiments (due to buck boost converters)
4. Whether need a shielding to noise reduction
Thank you.
Online Kleinstein
Re: DIY dual power supply
« Reply #1 on: June 08, 2019, 05:34:20 pm »
Quite a few of the cheaper 12 V SMPS (e.g. PC supplies) are isolation class I and thus need the earth ground for protection. For a dual supply this also implies that one may not connect them at will in series or as a +- configuration.
The cheap buck boost modules are usually not really good with regulation. They are more like voltage regulators and less what one would expect from a lab supply. So there can be some drop under load and difficult loads can be a problem.
The following users thanked this post: Dhanushka
Offline ocset
« Reply #2 on: June 08, 2019, 09:07:22 pm »
The  main problem will be how you ensure that the paralleled power supplies share the current. One will try and hog the current and supply it all itself.
Regarding noise you may need to add some small ceramics and ferrite beads if you want.
Beware adding too big capacitance to an smps output, as its possible to make ti go unstable if its too much.
Offline H713
« Reply #3 on: June 09, 2019, 07:02:45 am »
First I would ask yourself what you want to use this for- this will determine whether or not noise is a problem, for example, and how tight you need the regulation to be.
As an example, most off-the-shelf power supplies (and homebrew projects by others) are poorly suited to the work I do- primarily audio. I do not care if it goes down to zero volts, I hardly care if it goes below 10. But I do want +/- 10-30V @ 4A of extremely quiet linear power. My solution was a pair of Power One Linear 24V power supplies. With a few minor modifications and some decent pots these became a good bench supply that can do +/- 10-32V. The part I like about it is that I can actually run small power amps off of it, and it is similar in design to many console power supplies. Any off-the-shelf linear supply will be considerably larger and considerably more costly.
If, however, most of my work was logic based, why would I care if my power supply went up to 30V? I would, however, want something that could go down to just a few volts.
What I DO suggest is that you have some form of current limit function. That way you can decide how much of your project you want to destroy at once.
Back to the subject at hand, I haven't had good luck with buck/boost converters unless you buy very expensive ones, and even then, I find they can be pretty noisy. Of course, depending on what you play with, that may not be a disaster. A Raspberry Pi probably won't have an issue, a Class-A Neve module probably will.
