Author Topic: aluminum nitride PCB substrate  (Read 2935 times)
Offline CopperConeTopic starter
  • *knock knock*
« on: December 04, 2017, 12:10:55 am »
Can this stuff be drilled with carbide drills?
Can it take the impact of a copperset via kit?
I want to make my own RF PCBS.
Offline darrell
Re: aluminum nitride PCB substrate
« Reply #1 on: December 04, 2017, 12:57:06 am »
AlN is a hard brittle ceramic and is drilled with diamond or lasers. It's used for it's extremely high thermal conductivity. The usual metal on these ceramic substrates isn't solderable (the gold dissolves leaving a titanium adhesion film). If you are asking these questions, you probably want something more like Rogers RO4350B which can be drilled like FR4 and is copper clad. Even Isola FR408 is decent to 10 GHz or so. OSHPark uses that on their 4 layer service.
  • *knock knock*
« Reply #2 on: December 04, 2017, 10:14:36 pm »
I wanted to go up to 20GHz
