Roehrenonkel and 1 Guest are viewing this topic.
Static damage?These are 8GHz transistors, small geometries, easy to damage.
Quote from: 2N3055 on Today at 02:16:43 pmStatic damage?These are 8GHz transistors, small geometries, easy to damage.Not impossible I suppose, though I did get the same behaviour from all four transistors in the package, and I tried two separate packages
I needed a CA3086 transistor array but they've got crazy expensive, so I tried subbing a HFA3046. Long story short, it didn't work, but that's not really my question.I discovered that with the base and collector connected together, the CA3086 behaves like a normal diode like you'd expect. But the HFA3046 has negative resistance! I have attached my measured DC I/V curves for diode-connected, and for just the BE junction alone.How is this possible? Has anyone else seen diode-connected transistors exhibit negative resistance? Is there anything on the datasheet I should look for if I wanted to exploit/avoid this feature in future?Datasheet: https://docs.rs-online.com/8edb/0900766b8002512d.pdf
