Author Topic: All about Beryllium copper  (Read 6286 times)
Offline Kiriakos-GRTopic starter
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« on: June 06, 2011, 03:18:40 am »
If you wonder about the materials that the expensive probes or test leads,
hides under the hood ?
Read this link   ;)
http://en.wikipedia.org/wiki/Beryllium_copper
Offline nukie
Re: All about Beryllium copper
« Reply #1 on: June 07, 2011, 02:08:03 am »
The problem being Beryllium copper isn't exactly expensive  >:( there's no reason for them to charge more.
alm
  • Guest
« Reply #2 on: June 07, 2011, 06:24:18 pm »
Hi-Z scope probes use a very thin resistive core, something like NiCr, definitely not beryllium copper. A whole book could be written about the manufacturing of this wire (but isn't, it's usually considered trade secret). Another feature that make them expensive are the attenuation hybrid. The capacitor across the attenuation resistor should not display any frequency-dependent behavior, most will have a capacitance that varies with the frequency at high frequencies. This is not your standard ceramic cap.
For some insight about the intricacies of probe design, read Joe Weber's Oscilloscope Probe Circuits (available here), published by Tektronix around 1960. This is by far the most detailed description available.
Offline tecman
« Reply #3 on: June 07, 2011, 07:59:49 pm »
Bberyllium copper most often appears in electronics gear as a spring material.  Usually leaf springs of some sort.  Since beryllium is extremely toxic, its use as an alloy is seen less frequently today.
paul
Offline Neilm
« Reply #4 on: June 08, 2011, 06:53:17 pm »
You will quite often find it used for EMC screens, for example on the case to some computer cases.
Yours
Neil
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline Time
« Reply #5 on: June 08, 2011, 09:31:51 pm »
They just use BeCu in test leads because they do not wear out as fast as pure copper when being bent and flexed continually.  It has nothing to do with precision.
-Time
  • Country: gr
  • User is banned.
« Reply #6 on: June 08, 2011, 10:12:05 pm »
What about the part of " lesser sparks " ?
I was thought that this matters more than anything.
Offline Time
« Reply #7 on: June 09, 2011, 02:48:13 am »
That just means when you clank or drop it on something it doesn't produce sparks that ignite flammable gases in the air. It can still make electrical sparks.  Its still very conductive.
-Time
Offline RCMR
« Reply #8 on: June 10, 2011, 09:42:46 pm »
I recall during my time as an RF tech that many of the RF power transistors with ceramic bodies contained beryllium and we were warned not to crush or grind them due to the toxicity of that substance.
Just another nasty element found in this industry I guess -- along with cadmium, mercury, lead etc.
Although I seem to recall playing with a lot of lead when I was a kid and inhaling 60/40 solder fumes for decades -- hmmm, perhaps that does explain a few things  ::)
  • Country: gr
  • User is banned.
« Reply #9 on: June 10, 2011, 11:10:37 pm »
Are you talking about the MRF-317  BLV-25 BLY-87 BLY-89 ?  Or something more special than that ?
