So this is my DSP amp i designed, mostly from the typical applications in the datasheets, but maybe i missed something.
Im not 100% shure about the DIR9001 Part, since im a noob in digital things, will it work like this?
The Attiny in the Power/controll section is for switching 5V and 24V Off, when no music is playing for 15minutes. I plan on using the ADCs of it, to sense the audio signal from the Input of the DSP, via the 2 diodes, is it reliable to do it like that?
I will get help with the programming of the Attiny.
As for the rest, if something is wrong, im happy to know it.
