I'm looking for an enclosure. It needs to be about 180-250mm long, at least 110mm wide (need to accommodate 100mm x100mm PCB) and have sufficient depth for Speakon panel mount sockets and some 4mm binding posts. Sockets and binding posts can be at the left and right ends or on the rear (if the width is increased to at least 150mm).
The catch is I want to have a window to allow IR control signals in.
The Hammond 1591ETRD would work I guess as it is 191 mm x 110 mm x 61 mm, but it's not the aesthetic I'm looking for. I'd much prefer a black metal or plastic enclosure with a small IR window.
Does anyone have recommendations that won't involve costly machining work?
Thanks
