Hi Al (first post on this site!)
I'm designing a system with 2 different PCBs. First PCB has a THS4140 used to convert a single-ended analog signal to a differential signal. Second PCB has an ADC with differential input This differential signal needs to find its way to an ADC on the second board, via some sort of cable. I included a reference snapshot, in attachments, from the datasheet of the THS4140 in case you want a better visualization.
I was wondering if you had suggestions on which cabling solution might fit my needs? Was thinking some sort of twinax or twisted pair, but not sure if anyone has any better suggestions.
All input appreciated. Thanks!
