Hello,
We have a spec for 20W LED lamps to be powered from a train power source which is 18V to 137.5VDC.
In fact, its wider than that, there is an emergency requirement of 4W LED power for times when this supply goes down to 8V. (-but that might be when the emergency battery pack switchs in?)
Do you know what it is on the trains which is providing this DC power source? Is it a big battery bank?
I believe they are electric trains. For example, it’s the trains that will be used in the HS2 project, soon to come in UK.
Do you know what kind of source impedance this 18-137.5VDC power source will present to our 20W LED lamps?
We don’t have room for much input capacitance in the LED lamps, so we are hoping there’s not much wiring inductance going back to the power source. Do you know what the wiring inductance is likely to be?
Unfortunately, the client is not coming forward with much information on this for us.
To me , it sounds liek a really "dirty" , "dont give a damn" power source which is probably more concerned with getting energy from regenerative braking into batterys...do you reckon?
