Hi All,
I would like to sweep both through the current and gate resistor in my circuit simultaneously. Ideally I could also set the temp to 125 for example.
I have managed to get it to sweep through one at a time but not more than one simultaneously. I can't seem to find documentation online to do this.
Can anyone help?
this is what I am doing to sweep through one parameter.
.simulator SIMETRIX
.TRAN 20u SWEEP SINGLE PARAM=Current LIST 100m 200m 500m 1 2 3 5 10 15 20 25 30
.simulator DEFAULT
I have tried different syntax to try to get it to run but can't figure it out.
