Author Topic: Adding a PIR sensor to a string of LEDs  (Read 1592 times)
Offline sentry7Topic starter
« on: July 20, 2016, 03:07:26 pm »
Hey guys,
I have a string of decorative LEDs that's powered by 3 AA batteries. There seems to be a series resistor as well (looks like 5.1ohm, 2 watts?...I can't see it very well). I need the lights to turn on when people come into close proximity, so I want to add a pir sensor. The sensor is 3.3v, but I'm not sure about the current draw.
So...something like this?
Offline georges80
Re: Adding a PIR sensor to a string of LEDs
« Reply #1 on: July 20, 2016, 04:10:06 pm »
You say PIR sensor, but is that a raw sensor device or a module.
Raw sensor needs amplification and lens etc...
If a module then it must have some basic specs.
cheers,
george.
« Reply #2 on: July 20, 2016, 04:19:13 pm »
It is a module. Sorry, not at the bench ATM, will get back with some specs.
« Last Edit: July 22, 2016, 02:05:26 am by sentry7 »
« Reply #3 on: July 20, 2016, 05:01:02 pm »
If it is a 3V3 module simply put a 3v tap in the battery pack, so it will get a 3V supply. Many though are 5V modules so will run direct of 4V5. A 1000uF 16V capacitor across the power leads to the PIR will help it as the batteries age. These typically are a low power draw though, so should last quite a while on a set of AA cells. You can increase the series resistor for the leds to 10R without much light reduction, but with a good increase in battery life.
Online ajb
« Reply #4 on: July 20, 2016, 06:19:47 pm »
If the LEDs are blue, green, or white, then current draw is ~300mA.  I = (Vsupply-Vled)/R = (4.5-3)/5.1 = 0.294, or if they're red, I = (4.5-2)/5.1 = 490mA.
You haven't shown the LEDs in your diagram.  Assuming R1 is the current limiting resistor for the LEDs, then the LEDs should be in the same spot.  So Vcc->Resistor->LEDs->collector of the transistor.  This will work as long as the PIR produces a positive pulse when triggered; if it's inverted then you'll need to flip everything around and use a PNP transistor (or add a second transistor as an inverter).
Offline edavid
« Reply #5 on: July 20, 2016, 07:52:05 pm »
It's extremely unlikely that a battery powered LED string would draw that much current.
They could be lower voltage LEDs, with 2 in series.
Or there could be resistors in series with the individual LEDs in the string.
Or OP misread the value (OP, do you have a multimeter?).
« Reply #6 on: July 22, 2016, 02:00:49 am »
Sorry for the delay. So I did a meter check, and the resistor is indeed 5.1 ohms. I'm not sure about the power rating, I have a pair of calipers and can check the diameter.
Offline edavid
« Reply #7 on: July 22, 2016, 04:08:37 am »
Did you try measuring the current draw of the LED string when you connect it to the batteries?
« Reply #8 on: July 22, 2016, 10:24:01 pm »
Okay, I didn't measure the current directly, because I have a non-operational ammeter, but I got a voltage of 1.35v across the series resistor, so I = 1.35v รท 5.10ohms ~ 260mA. I'll find some specs for the sensor.
