Author Topic: Adapting laptop SODIMM to work in a desktop, is it possible?  (Read 10897 times)
Offline rwgast_lowlevellogicdesinTopic starter
    • LowLevel-LogicDesign
« on: March 26, 2013, 08:36:56 pm »
This is probably a goofey question but non the less I would like to take a shot at it, if it is reasonable. Ive been in a bad financial situation for quite a while and I have had to revert to an older HP desktop running XP with an AMD 2ghz single core and a gig of ram. A while back I did some work on a guys laptop including upgrading the ram, one of the stick I ordered for him was DOA, so I sent it back and had a replacement mailed out. Well it has been a year and the customer has never come back for his third gig of ram. It has just been sitting going to waste so I started thinking..... the ram is the same speed ddr2 that my desktop uses. As far as I know the only difference in laptop and PC ram is the form factor. I was wondering if it would be possible to solder up some kind of adapter or even just small wires to the chip and connect it to my desktop PC's Mother Board.
While the idea seems reasonable, I cant find any production SODIMM to regular DIMM adapters on the net. So I started thinking since this is hi speed maybe an adapter is not possible because it would locate the ram to far from the bus, maybe soldering wires to the leads of the ram would add to much capacitance, Im not sure? Like I said the idea seems simple enough but I am not uber hi speed digital engineer, only a hobbyist, I was hoping some one may be able to shed some light on what problems I may face.
Offline dr.diesel
Re: Adapting laptop SODIMM to work in a desktop, is it possible?
« Reply #1 on: March 26, 2013, 08:48:37 pm »
RAM is so cheap the adapter would cost more then just buying proper memory.
Offline M. András
  • Country: hu
« Reply #2 on: March 26, 2013, 08:55:56 pm »
yeah depends on speed size etc 32gigs of ram cost me 300bucks converted from our currency
Offline Teemo
  • Country: ee
« Reply #4 on: March 26, 2013, 11:02:49 pm »
The idea is interesting, but I do not think it is easily doable. It possibly makes more sence to trade that ram with someone.
If you still want to do it, there is too many pins to just solder in with wires! Only way to go is to design special PCB and must have socket for sodimm. Find out electrical datasheets for both types first, and see if those are compatible.
Offline nukie
« Reply #5 on: March 26, 2013, 11:08:43 pm »
Are you sure you search??! Because when I googled there are plenty of sodimm to dimm adapters.
Offline Fsck
  • sleep deprived
"This is a one line proof...if we start sufficiently far to the left."
Offline amspire
« Reply #7 on: March 27, 2013, 01:09:40 am »
quick google shows:
http://www.amazon.com/ValueAMP-DDR3-204pin-SODIMM-adapter/dp/B005F0E26S
That adapter costs $15 and we are only talking about a 1G RAM module.
You can buy 4G of quality RAM for under double that price.
I think the adapter has to degrade the RAM performance or reliability a little.
Offline gnif
« Reply #8 on: March 27, 2013, 05:50:53 am »
Doing this with wires would cause signal integrity issues, DDR traces are length matched so that the timing is precise, I highly doubt it would work.
