Author Topic: AD834 is such an excellent multiplier, why do we rarely see people using it?  (Read 1113 times)
Offline daisizhouTopic starter
  • Country: cn
Hello everyone
I plan to build a high frequency power measurement device,The general operating frequency is 800K-3Mhz,To measure RMS voltage and power, I looked at a lot of references.
I found the AD834 to be a very good multiplier,I plan to use non-inductive resistors to decay and eventually use the AD834 to measure.
But few people use it to make power measurement devices,I do not know why
https://www.analog.com/en/products/ad834.html
daisizhou#sina.com #=@
Online mikeselectricstuff
    • Mike's Electric Stuff
Cost mostly - you an get some really nice ADC/DAC/DSP for way less than the cost of that part.
Day Job: Mostly LEDs
  • Country: cn
But can the bandwidth also reach a maximum of 500MHZ?There is also 0.5% accuracy
Offline moffy
That's why it is expensive, making it uncommon, for me about $80 AUD at Mouser.
Offline andrewtaylor
The high price and it is single source only  from AD -- so that's main reasons.
Same with e the LT-chips for RMS measurement (10hz..50/100Mhz possible) -
obsolete since decade.
(btw. if you didn't aware: LT was sold to AD).
Offline dzseki
  • Country: hu
If frequency requirements are not very high , you can also consider AD835 (250MHz), which is a touch cheaper, and has already voltage outputs, plus with the added "+Z" input it can do a few more tricks too.
HP 1720A scope with HP 1120A probe, EMG 12563 pulse generator, EMG 1257 function generator, EMG 1172B signal generator, MEV TR-1660C bench multimeter
  • Country: cn
I remember the LT1088, but unfortunately it has been discontinued.
For RMS measurement, I only know that AD834 is the best choice.
  • Country: cn
Are AD834 and AD835 interchangeable?
I rarely see any enthusiasts using them to make RMS measurement circuits or other DIY works on the Internet.
Online RoGeorge
I've bought once a batch of AD835 from Aliexpress, in 2015.  It was $1.48/pcs in batches of 10pcs. and free shipping.
At first I was afraid it would be fake chips, though I've DIY a breakout board for one of those AD835, and measure it at low frequency on a breadboard.  The chip was indeed a working analog multiplier.  To this day, still didn't test them at high frequency.  AD835 should work up to 250MHz.
Source:  https://hackaday.io/project/7574-the-devil-is-in-the-details/log/26074-diy-breadboard-friendly-soic-breakout-boards
From traceable vendors the cost was many times higher, but I don't recall the official price.
« Last Edit: July 19, 2024, 08:15:21 am by RoGeorge »
  • Country: cn
At first I was afraid it would be fake chips, though I've DIY a breakout board for one of those AD835, and measure it at low frequency, on a breadboard.  The chip was indeed a working analog multiplier.  To this day, still didn't test them at high frequency, AD835 should work up to 250MHz.
From traceable vendors the cost was many times higher, but I don't recall exactly the official price.
Yes.AD834 sop8 package is very cheap, DIP8 may be slightly more expensive。
The reason why I chose AD834 is also based on its price. It seems to be very cheap. The purchase quantity can be 1 or 2, which is up to the buyer.
Online RoGeorge
That's about $0.48/pcs for a 500MHz AD834, right?  ???
The Analog Devices webpages for AD835 and AD834 list them as starting from $16.93/pcs respectively $30.56/pcs for 1ku.
Don't know what's the catch, but there must be a reason why the Chinese AD834 is more than 60 times cheaper.  :-//
  • Country: cn
Yes  It may be old, but for amateur players, it's not important as long as the chip function is normal
Offline moffy
Caveat emptor or buyer beware.
Offline dzseki
  • Country: hu
They are different. AD834 has a complementary current output ("open collector") that is somewhat awkward to work with. On the other hand AD835 has a single conventional voltage output.
Also AD834 is a pure multiplier with a transfer function: W=X*Y
While AD835 has an adder input oo, so the transfer function goes like: W=X*Y+Z
I've made various projects with AD834 and AD835 as a contrast modulator for high resolution CRT projectors for home theater enthusiasts.
I still have a few chips and boards laying around.
Offline Postal2
  • Country: ru
This chip (or similar) can be used to build a sound converter to speak with the voice of a clown.
