Hi morcibacsi
I received my eletronics parts (esp32, mcp2551, etc..).
in attachment, a dump RD1 - CDC, generate with ESP32 and MCP2551 + level shifter
thank you for your analyse
(I continue my tests with your library for Arduino, and library VAN Bus with ESP8266).
Edit:
in attachment, a 2nd dump.
when CDC not connected, push button on SRC CDC result "CRC_ERROR FF FF FF ..." in output serial console.
and when I connect CDC, the first output is also "CRC_ERROR FF FF FF ...", next i have good frame (see atachment).
