Thanks, ~2 years ago i had an interview for a vaping device manufacturer........It had all the following on the job spec...
*********************______**************************
• Highly competent in SMPS power supply design and familiar with most topologies (Buck, Boost, Flyback, LLC, Half-bridge, Full-bridge)
• Highly experienced in analogue and digital design, DC-AC and DC-DC systems, EMC testing and current regulations.
• Experience in analysing performance across process, voltage and temperature variations including environmental conditioning.
• Knowledge of battery technologies, specifications and performance. Able to test and select batteries for use in THP prototypes and appropriate safety circuits.
• Good understanding of best practice design for EMC and other safety & compliance requirements
• Experience in inductive power systems; including wireless charging, control and heating.
• Competent in modelling and simulating complex thermal and magnetic flux in FEA
• Knowledge and experience of PCB design and chipset selection for BT and WiFi applications and products
• Experience in writing and debugging software/firmware for similar hand-held electronic devices.
..And at the interview, they were asking me all about Diff amps, INAMPs, and common mode rejection ratio of opamps.
I am just wondering how this could be?...because a vaping device, as you kindly show, is just a resistive coil across a battery.
