Author Topic: Active filters noise issues  (Read 1057 times)
Offline Analog Frontend DesignerTopic starter
  • Country: ua
« on: June 29, 2024, 07:28:30 pm »
Currently I am involved in quite challenging AFE design for myography sensor application.
One of the impotrant issues for SNR improvement is filtering stages noise.
For example here is useful article explained the influence of high Q stages to overall output noise https://e2e.ti.com/blogs_/archives/b/precisionhub/posts/noise-from-active-filters-an-unwelcome-surprise
When I have tried to simulate the noise behaviour of LPF by means of LTspice, actually the lower Q section produces less output noise,
But I was a little bit confused that noise performance doesn't depend obviously on OpAmp type even if noise simulation is mentioned in Spice lib description.
For example, below are two sets of simulation results, first for more noisy (according to datasheet) TLV9042 Opamp and second set for much less noise MAX44260 Opamp. In both cases resistors and caps are ideal ones, so only Opamp noise should affect the final result.
But plots show that MAX44260 has more output noise, which is unexpected literally.
Is it simulation bug or incorrect LTspice work with third-party spice models?
Hope that in real life noise performance depends on Opamp type ans less noisy opamp will produce the less total output noise.
« Last Edit: June 29, 2024, 07:44:59 pm by Analog Frontend Designer »
Offline MasterT
Re: Active filters noise issues
« Reply #1 on: June 29, 2024, 08:03:02 pm »
I think, huge GBW difference plays role.
The following users thanked this post: Analog Frontend Designer
  • Country: ua
« Reply #2 on: June 29, 2024, 08:27:41 pm »
Might be, but some doubts about GBWP, because noise peaking located at the same low frequency (about 500Hz).
But I believe thet actual noise performance should be dependent on opamp voltage and current noise
Offline Benta
« Reply #3 on: June 29, 2024, 08:50:29 pm »
Hehehe.
You've just been bitten in your behind by the Sallen-Key filter. It has no good features, except being easy to calculate.
Throw it in the waste bin, and try with a MFB filter instead.
Offline magic
« Reply #4 on: June 29, 2024, 09:09:14 pm »
In SPICE resistors have Johnson noise, so you see a combination of that and opamp noise (if it is included in your models).
Test the models in simple voltage follower application to see if they match their corresponding datasheets. Try an ideal opamp (this is noiseless) and see how it works, this will give you the amplified resistor noise alone. Calculate noise gain vs frequency by means of AC simulation and see if your result is consistent with noise density specs times noise gain of the circuit.
  • Country: ua
« Reply #5 on: June 29, 2024, 09:16:27 pm »
Hehehe.
Actually, MFB has worse noise behaviour.
look at plots below. This is the same filtred based on MFB topology
Offline Benta
« Reply #6 on: June 29, 2024, 09:34:05 pm »
TBH, it's not clear what you're measuring where.
I can only see that you're biasing the input to 3.3/2 V, and injecting a noise signal.
  • Country: ua
« Reply #7 on: June 29, 2024, 09:34:37 pm »
You are right.
Looks like spice models from TI doesn't works correct in LTspice noise analysis.
TLV9042 was replaced by ideal opamp and plots compared. Very similar to ideal.
  • Country: ua
« Reply #8 on: June 29, 2024, 09:40:01 pm »
it's just a noise analysis in LTspice. V3 serve as exitation (in specified frequency range) and noise measured at OUT node/
Offline Kleinstein
« Reply #9 on: June 29, 2024, 09:40:49 pm »
Many Op amp models don't include noise.
Offline Benta
« Reply #10 on: June 29, 2024, 10:07:06 pm »
Nothing in your schematic indicates that. If LTSpice defaults to the "OUT" label, nice for you. But we don't know. It might also default to the next node in your circuit.
Always be explicit.
  • Country: ua
« Reply #11 on: June 29, 2024, 10:28:02 pm »
Yes, and actually it was a reson of misunderstanding.
Below two plots of MAX44260 and TLV9042 pure noise simulation as unity-gain followers.
In case of MAX results completely corresponds to datasheet figure. For TLV, noise plots doesn't match to specified in datasheet.
Offline Terry Bites
« Reply #12 on: June 30, 2024, 02:00:05 pm »
See if TINA-TI models this opamps noise correctly.
also see www.analog.com/en/resources/media-center/videos/5579265856001.html
  • Country: ua
« Reply #13 on: June 30, 2024, 03:20:40 pm »
also see
Tina-TI gives the same noise plot as LTspice (for unity gain configuration). And both are wrong, much more better, than datasheet figure show.
So, one extra reason to check everything you can, even manufacturers models.
Offline Vojtech
  • Country: cz
« Reply #14 on: June 30, 2024, 03:45:41 pm »
Reduce values of the resistors significantly, R2+R3 alone give about 180 nV/sqrtHz of noise, Op Amp isn't so big a problem.
The following users thanked this post: Roehrenonkel, Analog Frontend Designer
  • Country: ua
« Reply #15 on: June 30, 2024, 04:59:14 pm »
About 70 nV/sqrtHz R2+R3 give.
According to my understanding this resistors noise geometrically added to a
Opamp input noise and gained  (Q and f dependent ).
Also, resistors current noise also present, but it depends on resistor type (MELF will produce the lowest possible current noise among others widely used types).
About resistors values, there should be compromise. To my mind, as lond as you can use NP0 capacitors, you should use the lowest possible resistors values. Because X7 series has much more capacitance deviation across the temperature range, worse initial tolerance and piezo effect. Although, i have never observed the last one (sufficient electrical nouse generated by mechanical impact)
Offline Sensorcat
  • Freelance Sensor Consultant
    • Sensorberatung
« Reply #16 on: June 30, 2024, 09:00:34 pm »
Conclusion: The Sallen-Key filter is already too complicated to start studying something new (effect, method, ...). If you want to find out or learn something new, always use the most simple item, structure, or system possible. Once the new thing is understood, move on.
  • Country: ua
« Reply #17 on: June 30, 2024, 09:42:43 pm »
However, now it isn't looks complicated :). The reason was in erroneous spice models from TI. To understood this, sure some separate simulations was required.
Sallen-Key filters still better solution when noise might be a concern, because noise gained only near the cutoff frequency region. Filtering stages should utilize the lowest possible Q filter sections.
And another valuable conclusion, for noise-sensitive applications filtering stages should be placed after preamplifier stage, in order to minimize the filter noise contribution into the final output signal.
Offline Benta
« Reply #18 on: June 30, 2024, 09:59:24 pm »
Keeping the noise part separate, you have a different problem with the Sallen-Key.
It will turn into a HP filter at some point. This is inherent in the topology and needs attention. MFB does not have the problem to the same degree and is much easier to "tame".
I suggest you read this TI app note (pay attention to p. 14...17):
https://www.ti.com/lit/an/sloa049d/sloa049d.pdf
Offline Sensorcat
    • Sensorberatung
« Reply #19 on: June 30, 2024, 10:14:41 pm »
Everything looks easy when solved.
Yes, and this is my point. If you had started with the most simple configuration possible, instead of the circuit you wanted to have in your application, you could have found out yourself what is going on. But it's your choice if you want to learn a principle from this episode, or if you want to hit the same wall next time, next project, next issue, again.
  • Country: ua
« Reply #20 on: June 30, 2024, 10:59:19 pm »
Topology selection is always tradeoff among different factors and design limitations. Mentioned SKF drawback also known as "stopband leakage" and thats why so important to have correct opamp model for simulation.
Actually, in most cases it isn't so dramatic. At first, you can "move" the leakage point by choosing opamp GBW and output impedance. And second, powerful method to reduce the stopband leakage - use the odd-order filtres with passive first-order stage.
For example, Bode plot of 3-rd order LPF as shown in first post. At least -79dB attenuation at maximum stopband leakage point (and @350kHz, which is opamp GBW). For my application it's more than enough.
But I agree, in some cases MFB might be a better solution, especially when unwanted frequencies are broadband and cover several decades above cutoff.
« Last Edit: June 30, 2024, 11:02:06 pm by Analog Frontend Designer »
Offline Benta
« Reply #21 on: June 30, 2024, 11:21:29 pm »
As long as you're aware of the issue, it's your design choice as engineer. I'm fine with that.
But 95% of designers think the Sallen-Key is great (which it's not!). That bothers me a bit.
Online mawyatt
« Reply #22 on: July 01, 2024, 03:02:54 am »
Besides its simplicity, an often overlooked characteristic of the Sallen-Key LPF is the almost total lack of sensitivity of filter DC Gain to the Op-Amp and all components characteristics in the Unity Gain LP Configuration.
This is one reason we often used the SK for Low Pass Noise Filtering precision voltage references.
Best,
~Wyatt Labs by Mike~
The following users thanked this post: ch_scr, Analog Frontend Designer
Online mawyatt
« Reply #23 on: July 01, 2024, 03:23:27 am »
Many Most op-amp models lack fidelity, especially in the output section, which is the fundamental cause of the dreaded "stop band leakage". We discussed this here awhile back (and way way back in an EDN article).
Improving Stop Band performance does take away from the simplicity of the SKF as it requires added components to lower the effective op-amp output impedance, either a buffer or output bias "bleed" resistor.
One advantage of locating a 1st order low pass section at the overall LP filter input is this helps attenuate the higher frequency components of the input signal from entering the active op-amp and reduces the potential IMD issues.
When designing high order active filters one always wants to locate the highest "Q" filter section at the overall filter end if possible, this maximizes the overall filter DR wrt waveform limiting.
Best,
« Last Edit: July 01, 2024, 03:29:27 am by mawyatt »
