Hello everyone, I'm new to the forum.
Hopefully this question will be simple for an analog expert.
I have a project where i need to isolate a certain frequency and measure its strength.
I plan to use a Sallen-Key bandpass filter, rectify the output from it, and feed that onto a leaky capacitor (integrator) where i can then measure the voltage from time to time.
I could simply place a rectifying diode between the filter and the integrator, but then i will lose any signal smaller than 0.7 V.
What i would prefer to do is this: (see first image SK1)
As the diode is inside the feedback loop then its voltage drop should be compensated for (?).
My question is, would it work, or will the diode upset the workings of the filter?
I've seen some circuits with the diode within the feedback loop, e.g. here:
http://www.tu-varna.bg/tu-varnaetm/images/IE_EN/L11_Rectifiers.pdf But those aren't filters.
Failing that, i could compensate at one of the inputs, like this: (see second image SK2)
The trouble being that if the two diodes don't have exactly the same Vf then it will introduce an offset error. But i should be more able to live with that.
I want a simple solution that adds the minimum of extra components, as space will be tight on the board.
It doesn't have to be really accurate, provided i don't lose those weak signals!
I don't yet have much experience in electronics, so maybe i overlooked some obvious solution. Any help would be really appreciated.
I'll be out for the next week, so happy Christmas all.
