Author Topic: Active filter design : 2nd order sharp roll-off  (Read 3822 times)
Offline RutherbergTopic starter
« on: February 04, 2019, 03:10:41 pm »
Hello,
All is in the subject, I have a hard time to design a non-inverting 2nd order high pass with a sharp roll-off.
I would like to keep the -40db/decade, but with a sharper roll-off.
With a classic 2nd order, the roll-off is too slow.
What type of filter should I use for these results ?
Thanks
Offline Conrad Hoffman
    • The Messy Basement
Re: Active filter design : 2nd order sharp roll-off
« Reply #1 on: February 04, 2019, 03:22:04 pm »
2nd order is only good for so much. You need a higher order filter.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: February 04, 2019, 03:23:26 pm »
Yeh... how sharp are you looking for?
Consider this: you only gave one number, and it's not even the property you're trying to optimize!  That doesn't give us much to go on.
How much peaking can you tolerate?
That's the only variable you have control over.  To get a sharper cutoff, you need a higher order filter, even if you don't need the cutoff attenuation that gives.
If you can afford an elliptical filter, it can be much sharper, but it will likely take more parts, or more order (there's hardly such a thing as an elliptical 2nd order), though it can still have the same asymptote.
Mind that, if this is an active filter, the attenuation may level off anyway, due to the amp's finite gain.
Seven Transistor Labs, LLC
Offline Benta
« Reply #3 on: February 04, 2019, 03:51:19 pm »
Look into Chebyschev filters. They have a sharper initial rolloff, but end at -40 dB/decade.
Downside is, you'll have ripple/peaking in the pass band.
« Reply #4 on: February 04, 2019, 04:27:48 pm »
Ok thanks, I may have found a hint of what I try to achieve.
Attached, an op amp circuit with a transistor gyrator. The curve of the peak is what I want.
The idea now is to keep same gain at peak frequency after the peak frequency, to make a high pass filter, thus the roll-off will be fast. I don't know if I'm clear.
How can I achieve this ?
Offline Benta
« Reply #5 on: February 04, 2019, 05:08:21 pm »
Whether you use a gyrator, a classic opamp active filter or or a conundrumbulator is irrelevant.
A second order response is a second order response, regardless of how you do it.
Offline RandallMcRee
« Reply #6 on: February 04, 2019, 05:55:29 pm »
Here:
https://www.analog.com/designtools/en/filterwizard/
Try this, before posting again. Let us know if you have questions. Google anything you don't understand.
Ask further questions if you can't understand what you googled.
« Reply #7 on: February 04, 2019, 06:15:39 pm »
Thanks, but if I come here, it's not because I want to waste anyone's time, it's because I googled everything I can. It's been about 3 days that I work on that and it drives me nuts.
I tried Filter Wizard for about 1 hour today, still not what I need.
I'm close to find the solution, look at my last post. The rising curve of the peak is what I need, now I need to keep the gain maxed after the peak frequency, and I don't know how to do it.
Offline T3sl4co1l
« Reply #8 on: February 04, 2019, 06:25:35 pm »
Can you please draw a Bode plot of what you actually need?  (That's a log-log graph, vertical gain (log, so equivalent to dB), horizontal frequency, with straight line asymptotes showing where you want the pass and stop bands, and showing some allowable peaking, or required cutoff sharpness, at the corners between straight segments.)
Offline Benta
« Reply #9 on: February 04, 2019, 06:55:24 pm »
Yes, but you can't get to a solution that way. Combining a band pass filter with a high pass filter just won't fly, the way you are approaching it. If you want a steeper cutoff, you'll need to increase the filter order, there's no way around it.
An alternative approach is to go digital and use an FIR filter, but...
Offline grouchobyte
  • Country: cn
« Reply #10 on: February 05, 2019, 10:23:10 pm »
Try this. Your requirements are a little fuzzy,but based on comments you made I took a stab at it. Is this what you want/need? If not, please clarify with better requirements like ( for example):
high pass?
nth order?
fidelity in the time domain/ dont care?
input/output impedance?
pass band attenuation?
pass band ripple?
topology preferred ( active/ passive, sw cap...etc)
rolloff?
Let us know and we can help you optimize it
« Last Edit: February 05, 2019, 10:45:44 pm by grouchobyte »
The following users thanked this post: Rutherberg
Offline grouchobyte
  • Country: cn
« Reply #11 on: February 05, 2019, 11:07:02 pm »
your want better rolloff?.....try this. Sim attached
You're welcome!
@grouchobyte
« Last Edit: February 06, 2019, 12:34:20 am by grouchobyte »
Offline nick_d
« Reply #12 on: February 06, 2019, 04:38:03 am »
The easiest way to meet this requirement is to put the correct number of Sallen & Key high pass filters in series. Each Sallen & Key filter uses one op-amp and two RC networks to deliver (in voltage) 6dB/octave = 20dB/decade or (in power) 12dB/octave = 40dB/decade of roll on. See here: http://sim.okawa-denshi.jp/en/OPseikiHikeisan.htm
The choice of response type (Butterworth, Bessel, Chebyshev etc) is independent of the number of sections. What these options do is change the behaviour slightly near the cutoff. A few octaves away from the cutoff the behaviour will be basically the same for all response types. If you have say 3 sections with 6 RC filters, then you set the response type by tweaking the 6 RC values so that each has a slightly different cutoff, using a table that is pre-computed for cascaded Sallen & Key filters of a particular number of sections.
There isn't really anything more to do. It is a completely straightforward exercise in plonking down the example circuit and reading the tables.
cheers, Nick
edit: clarify voltage dB vs power dB
« Last Edit: February 06, 2019, 06:27:21 am by nick_d »
« Reply #13 on: February 06, 2019, 10:46:07 am »
Thanks a lot for all the answers despite the lack of clarity of my request.
Attached, 2 circuits simulated, green curve is a high-pass Sallen Key calculated with okawa-denshi calculator, blue curve is a 1-stage Chebychev calculated with Analog filter wizard, cut-off is approximatively 3,7kHz for both.
The rough red curve is what I need : at least the roll-off of the chebychev or sharper at approx. 3.7kHz, but limit the attenuation.
I would like to have 1kHz attenuation at about -14dB.
Filter ripple is not crucial, but better under 2dB.
Also, I would like to keep the numbers of stages to a minimum, ideally 1 or max. 2.
How can I limit the attenuation ?
high pass?
nth order?
pass band ripple?
rolloff?
- High pass
- 2nd order
- Don't care
- Don't care, will be buffered
- minimum possible
- max. 2dB
- Don't care, but this circuit will be audio and thus noise sensitive
- faster/sharper than the green curve attached
Is it more clear ?
Thanks
Offline nick_d
« Reply #14 on: February 06, 2019, 12:04:34 pm »
Are you happy that from 0 to 1kHz you have exactly 14dB attenuation, and then after that you have the Chebyshev? Since your circuit will be buffered, that is easy to do. 14dB is a factor of 25 (calculate by 10^1.4) if you meant by voltage, or 5 (calculate by sqrt 25) if you meant by power. So you create the Chebyshev filter and then present your buffer with a voltage that is 1/25 the original signal plus 24/25 the filtered signal. You do this with a resistive divider. Like this:
orig
 [ ] 24k
  *--- out
 [ ] 1k
filt
The voltage at "out" will be the weighted average of "orig" and "filt", however make sure your buffer doesn't take much current from it or it will reduce the accuracy. The best way to do it is have "out" be either the + input of an op amp in voltage follower configuration, or the virtual Earth of an op amp in inverting configuration. This ensures an accurate weighted average or sum respectively.
cheers, Nick
Edit: are you sure your Chebyshev is one stage? A Chebyshev has at least 2 RC filters, since what makes it a Chebyshev is the adjustment of the two RC cutoffs relative to each other. I think your blue and green lines have same roll-on but different response types. May be wrong but possibly 1 stage means two RCs?
Edit: swap the 1k and the 24k.
« Last Edit: February 06, 2019, 12:15:59 pm by nick_d »
Offline Karel
« Reply #16 on: February 06, 2019, 03:14:16 pm »
I misspoke, I would like -14db from pass band to 1kHz, and approx. -20/-22dB from pass band to 100Hz. Just like the red trace on the graph.
I tried with 1k and 24k, it limits the attenuation, but attenuation curve is not smooth, I got a dip at about 1kHz.
Yes, by one stage I mean one op amp.
Yes, I tried too.
« Reply #17 on: February 06, 2019, 04:52:47 pm »
You can do a nice 4-pole filter with a single opamp. See my program link in this thread- https://www.eevblog.com/forum/projects/third-order-filters-with-a-single-opamp-are-possible-after-all/25/
There can be component sensitivity issues with any higher order filter, but I've had little trouble.
Offline nick_d
« Reply #18 on: February 06, 2019, 10:59:06 pm »
Can you clarify if you are talking about power or voltage? Assuming voltage, you cannot get 6dB/decade. You can get 10dB/decade which might be adequate. Assuming power, you can get 20dB/decade which is steeper than you need. What you will have to do is construct the response stepwise.
So, you can have cutoffs at 100Hz and 1kHz. This gives you 3 signals to work with: original (freq 0..infinity), first filtered (freq 100..infinity) and second filtered (freq 1k..infinity). A weighted average of these can give you the stepwise response that you require.
If yoy want the steps to be as gradual as possible, use one RC. If you want the first step gradual and the second sharper, use one RC for the first filter and the two-RC Sallen-Key for the second. You can design what you need.
That shouldn't happen. Can you show your circuit? You probably loaded down the resistive divider by taking current from it. Use one of the techniques I mentioned (mean and voltage follower, or summing junction).
More sophisticated responses can be constructed with digital techniques.
cheers, Nick
Offline grouchobyte
  • Country: cn
« Reply #19 on: February 07, 2019, 12:38:22 am »
Hows this? You can tweak this for desired response below 1Khz. Your desire to use one stage is a little unreasonable since you are already asking too much. Here in America we call that putting 50 lbs of manure in a 10 lb bag. Use a quad opamp and 0402s or tell your boss/client about the manure conundrum and ask him how he would solve it
@grouchobyte
« Last Edit: February 07, 2019, 08:37:41 pm by grouchobyte »
The following users thanked this post: Rutherberg, schmitt trigger
Offline nick_d
« Reply #20 on: February 07, 2019, 07:52:52 am »
@grouchobyte that is a cool circuit. Kudos for the effort to design and simulate. At first I could not figure out why you had low passed the top branch. But then I realized that in my suggested way, adding the original signal to the high passed signal, the high passed signal will be significantly phase shifted as it starts to roll on, initially causing cancellation until the phase shift reduces throughout the pass band (it would be 180deg at DC, 90deg at cutoff and 0deg at infinite frequency?). This must be what OP complained of, whereas your low pass starts to roll off and add phase shift just as the high pass rolls on, to get reinforcement?
cheers, Nick
The following users thanked this post: grouchobyte
Offline grouchobyte
  • Country: cn
« Reply #21 on: February 07, 2019, 09:40:19 am »
cheers, Nick
Nick
Your assessment is correct in terms of the overlapping technique of the LP and HP sections. I guess 45 years doing analog design for HP, Tek and a dozen other giants has its benefits. Your suggestions actually led me to the current solution. The whole exercise including drawing it up in LTspice took me about 20 minutes. The hard part was reading through the OP’s posts and trying to extract the requirements. I am not certain it meets his needs 100%, but it is close and leaves a little for him to tweak and learn. (I am pretty sure we may be asked to assist in getting it dialed in) I have a PhD client that reminds me of the OP in the way he defines his requirements ( no offense to the OP) so it’s all in a days work for me. Cheers!
grouchobyte (Bob)
« Last Edit: February 07, 2019, 06:18:17 pm by grouchobyte »
« Reply #22 on: February 08, 2019, 08:30:15 am »
@grouchobyte cool circuit indeed, thanks a lot for the effort !
It's starting to look like what I need. The limit of attenuation to approx. -20dB is good and the knee at the cut-off frequency is sharp enough.
Now the idea would be to make the slope more progressive (see attached, the red curve) but keeping the sharp knee at cut-off frequency, if only it is possible of course.
I messed around for hours with your simulation but I can't get the results I need.
The closer I can get is with the second circuit attached, but the knee at cut-off is not sharp enough
Offline T3sl4co1l
« Reply #23 on: February 08, 2019, 08:32:42 am »
You're asking for fractions of a dB tweak, I don't see for what purpose that would be productive.
Offline ogden
  • Country: lv
« Reply #24 on: February 08, 2019, 09:54:46 am »
It won't be achievable w/o precision capacitors/resistors (or trimpots) anyway. I would suggest to run Monte Carlo simulation for selected tolerance (spread) of resistors and capacitors to see possible range of the error. As an illustration LC filter simulation (10% inductors and 5% capacitors):
