Author Topic: Array capacitors - how well matched are they?  (Read 596 times)
Offline axemasterTopic starter
« on: November 12, 2021, 05:58:16 pm »
I'm building a circuit that requires quad well-matched capacitors, NP0, in the 50-500pF range. "Well-matched" means ideally within 2%. Each cap will be from a signal line to GND, so bussed caps are OK.
I've looked at X2Y caps but they only provide 2 matched capacitors.
I also looked at standard array capacitors, which do have 4-cap arrays. But, the datasheets don't say anything about the matching.
Example digikey page: https://www.digikey.com/short/92m3q85q
I will be using several thousand quad caps, so manual measuring and matching is not a viable option here...
Does anyone have wisdom to share about this?
Online TimFox
Re: Array capacitors - how well matched are they?
« Reply #1 on: November 12, 2021, 06:49:39 pm »
The Kemet data sheet for the C0G quads says nothing about matching.  The only advantages they quote over singles is volumetric:  i.e., they take up less board space.
Obviously, they are not intended for matching tolerance better than the absolute tolerance, as opposed to some resistor networks.
Offline wraper
  • Country: lv
« Reply #2 on: November 12, 2021, 06:58:16 pm »
They don't specify matching tolerance at all. And according to my measurements of higher capacitance types (X7R, >=1nF) it's not better than taking 2 random capacitors from the same batch. IMHO just use separate capacitors with 1% tolerance, they are not that much more expensive than 5%, and most likely will be cheaper than a 5% array anyway.
« Last Edit: November 12, 2021, 07:04:58 pm by wraper »
