What are your requirements?
You know 2 phase AC signal could have alternating phases. My power board has 2 sets of mentioned circuit. I need to configure a system where, one phase is conducting through TRIAC and other will inactive and vice-versa. The sign of current and voltage on MTI,MT2 of TRIAC depends on 4 axis consideration and pulse voltages applied to Gate.
Sorry, I don't understand what you're trying to do. A two phase AC signal is two sine waves with a 90
o phase shift. A TRIAC won't give you a two phase signal.
Why not simply use an optically isolated TRIAC such as the MOC3022 or MOC3041, depending on whether zero-crossing switch on is required or not?
Yes, my system contains MOC3020, but need a TRIAC also, (BTA40, BTA41, BTB41).
I think zero-crossing is required. Do you have any suggestion? Let me know what other parameter/factors I need to consider during simulation.
Yes, a TRIAC is required with the MOC3022 or MOC3041. They are more suited to driving a TRIAC, than a photo transistor opto-coupler.
The MOC3022 has no zero crossing and will turn on, whenever the photo diode is activated.
The MOC3041 has a zero crossing unit, which means it will only turn on when the voltage across it is near zero.
Zero crossing cuts down on noise because the TRIAC is only fired when the voltage is low, therefore there's no abrupt increase in current which emits electrical noise. It's useful whenever a load needs to be switched either on or off. The down side is zero crossing cannot be used with phase control. It's no good if you want to dim a lamp.
There are schematics showing how to use the MOC3022 and MOC3041 on the datasheets which I provided links to in my previous post.
In simulation software I didn't find a good couple of them.
What doesn't your simulation software include models of the MOC3022 & MOC3041? If so then it doesn't matter. You don't need to simulate the entire circuit. Just use the example schematics on the data sheets. Don't rely too much on simulation, which is not perfect. There are circuits which will work in simulation but not in real life and circuits which work in real life but not on most simulators.
