Hi there,
I'm trying to build a linear power supply with a "wide" voltage range (1.25-30V), and as I intend to use it mainly at low voltages I don't want to have a single 30V input, it would be a huge waste dissipating so much energy. I have a dual secondary transformer, which provides 2x15V. I thought I would use a relay to switch between 1 output level (15V) or the second one (30V, outputs are in series) as in the provided schematic. I have a 12V fan running on the voltage regulator output. I enter a 5V signal on the relay to switch between both
I built the circuit and tested it, but I had a problem: the fan ran very fast and loud, before the fuse blows.
Apparently the fan got 30V and not 12V... The low level DC going out of the diode bridge is in fact 30V (well, 42Vdc actually, as it's unregulated and without a load). I probed the voltages on the bridge it and I was really surprised: 18VAC input, 42Vdc output relative to ground.
I suppose there is a simple explanation but I'm not used to that kind of AC/power circuits so I fail to see what it could be.
The earth / gnd reference was not connected in my test, I wasn't sure about that either. Maybe the problem comes from a difference in GND in both output ?
Any help would be appreciated.
