Author Topic: Are flex PCB current tolerances the same as regular boards?  (Read 1998 times)
Offline MarmottaTopic starter
« on: December 01, 2018, 02:24:32 pm »
I'm starting to design my first project using a flex PCB and was wondering if anyone knew how much current they can support? I've seen a bunch of different online trace width calculators online, but they all seem to be targeting regular PCBs. My project needs 5V @ 3 amps max and was wondering if that is something a flex PCB with a wide enough trace (e.g. 3.5mm) would be able to support or not.
Offline sanwal209
Re: Are flex PCB current tolerances the same as regular boards?
« Reply #1 on: December 04, 2018, 10:29:13 am »
Yes, It will with 1oz copper
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: December 04, 2018, 10:37:53 am »
OSHPark have just started offering flex , some specs here http://docs.oshpark.com/services/flex/
Day Job: Mostly LEDs
Offline helius
« Reply #3 on: December 04, 2018, 10:51:02 am »
Using printed solder mask, not coverlay, which could be an issue for some assemblies exposed to flexing.
« Reply #4 on: December 07, 2018, 03:10:58 pm »
Thanks for the responses. I'll knock something up in Kicad and see how much OSHPark would charge for a one-off (or three). Assuming there were no issues with the board design, I'd probably be looking at making about 10-20 of them, so other makers might be more suitable, as the prices drop dramatically when quantities are scaled up a little.
