I considered using that particular power meter pzem-061 but as I recall, it does not include a power factor spec, so I wasn't sure if it has true power.
Peacefair says:
"There are three types of power: active power (P represents / unit W), reactive power (Q represents / unit Var), apparent power (S represents / unit VA).
And the power of our product is active power.
Active power is calculated as: P = U * I * cos?, cos? represents the power factor, for purely resistive loads (such as incandescent, heater, etc.) the power factor is generally close to 1, for inductive load and capacitive load, the power factor is between 0-1; so when you test the purely resistive load, the power(P) is substantially equal to or close to U * I; but when you test inductive or capacitive loads (such as refrigerators, washing machines, televisions, computers, etc.), P <U * I . As for the specific number is related to the power factor, for each appliance has different power factor, so please believe the value of our product. "
DL69-2048 I use (LED) displays power-factor and it shows true power.
