I used the TPS562208 recently (same as the '2201 except at light loads) and I really did not like it. As thinkfat points out, the layout is difficult due to poor pinout choices. (That's the real reason I personally like the TPS61247: good layouts made easy.) We found output ripple to be unusually high, but that was probably related to another problem. This regulator is
exceptionally fussy about output capacitance, all three of its value, its type, and its physical location. The datasheet really does not make clear how important getting this right is with this regulator, though it is, technically, all in there, in that if you do exactly what the datasheet says, the part will work, and if you deviate more than their allowed bounds, you might be very sad.
The failure modes we observed with this annoying part were interesting. It likes to drift away, presumably as it heats up. So if you bring up a board and test its power rails, it might pass. Leave it running and come back in an hour and it might be failing. And give it to the software guy to program, whereupon he puts it near a pile of warm computers, and it might have run off into the woods, possibly never to come back. Or, possibly, when he dumps the broken piece of junk on you to fix, you don't get to it until the morning, when it's cold and doesn't misbehave at all... yet.... Less rantingly and more usefully, there were four symptoms we observed when the output capacitance is not perfect: regular old high noise on the output, large sawtooth waves (in the 2V p-p range) on the output, loss of regulation (5V output idling at 5.8V), and total loss of regulation (running off toward the input rail).
These behaviors are not really all that surprising if you know what's in the box, but I feel like this poor thing ought to have been at least a little bit better behaved than it was. Then again, it's the cheapest thing in (this section of) the TI catalog, so what did I expect....
Honestly any of the parts in this thread will work for you. If you're cost-sensitive, avoiding LT will help your wallet. The LMR36xxx and TPS56x20y families are nice if you need pin-compatible part upgrades for more current. If you're just powering a small Spartan-6, that's not too bad. I'd offer to share an old design of mine that does that, but there's really not much to it. Showing off that I can make four buck converters and the decoupling scheme from the datasheet is not worth scrubbing the identifying information.... If I were you, I'd pick based on:
- Ease of assembly/rework
- Total solution size
- Ease of layout
- Price
- Output noise
- Whichever one makes you feel warm and fuzzy inside. If any.
In whatever order is most important to you. This isn't a particularly challenging application and so any of these parts should be suitable.
