Author Topic: Looking for simple DIY sine wave generator plans  (Read 21968 times)
Offline blackdog
  • Please stop pushing bullshit...
Re: Looking for simple DIY sine wave generator plans
« Reply #25 on: September 12, 2013, 12:19:06 pm »
Wy not build my "Low Cost, High Performance" Sinus Gen...
It is designed around a NE5532AN or if you want lower distortion higer frequentie range use a OPA2134.
Its stable
Almost no AGC bounce
Low Output Impedance,
Output voltage <1mv to 10V, 2 range.
Good level flatness
Low distortion
Sync output
Schematic
You need to make your own opto with a white LED and a LDR resistor.
If you want to know how to make de OPTO, take a look at my topic on this Dutch website, is has a lot of pictures how to make the OPTO.
http://www.circuitsonline.net/forum/view/114296/1
Kind regarts,
Blackdog
Necessity is not an established fact, but an interpretation.
Offline dannyf
« Reply #26 on: September 12, 2013, 09:53:42 pm »
does anyone know of a simple, stable - and preferably cheap - circuit to generate sine waves up to at least 200Khz?
You need 3 wires to control an ad9850 module. A 8-pdip mcu can be programmed to do that, a potentiometer to control the output frequency. Fairly easy to do if you are willing to do some programming.
Gazucha
  • Guest
« Reply #27 on: September 13, 2013, 02:45:39 am »
Why not build my "Low Cost, High Performance" Sinus Gen...
Kind regarts,
Blackdog
 Hi Blackdog,
 thankyou.
 That looks well within my capabilities and is very much the sort of design I was hoping for.
 Good man.
 Gaz
Offline dannyf
« Reply #28 on: September 13, 2013, 10:52:01 am »
Cut a short piece of straw and stick your LDR on one end and your LED on the other.
Done.
