Several project that I made end up with an 7 segment and tactile switch. Which is not perfered by user.
So, I would like to ask the way of making a n professionl looking front panel control.
- Button , instead of tactile button what elese button v by the way I saw some project using a tactile switch pressed with some flex rubber or plastic button , I don't what it's called
- Display 7 segment is it installed on flex PCB, or having a gap of frame to illuminate through.
By the way I always love the panel of oscilloscope with somekind of rubber button with LED illuminating underneath. After I saw a rigol ocsilloscope tear down it has a switch on front PCB as in attached file
What it is called?
Could you please share the knowledge or project that had been done?
Thank you
