Author Topic: Old Scanner type?  (Read 1251 times)
Offline Chris56000Topic starter
Old Scanner type?
« on: January 28, 2019, 07:00:21 pm »
Hi!
Just a quickie one - I know it's only a minor point - I'd like to build this UV LED exposure box. . .
https://lytrax.io/blog/projects/diy-uv-exposure-box
. . .but it would be handy to have the same or a very similar scanner as a base as the model depicted already has 12V and USB inlets ready for use and two buttons on the front in a convenient place all ready for use!
Does anyone recognize this make and model of scanner so I can look for the same or one very similar?
Chris Williams
« Last Edit: January 28, 2019, 07:05:56 pm by Chris56000 »
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
Offline webgiorgio
Re: Old Scanner type?
« Reply #2 on: January 29, 2019, 12:34:07 pm »
Any old scanner will work.
Here is mine http://www.ingdemurtas.it/elettronica/bromografo2/
« Reply #3 on: February 25, 2019, 07:23:46 pm »
 Hi!
Thanks for that – the reason I was interested in the same model as per the original prototype as it already has USB and power holes provided to give a neat completed finish plus a convenient sloping front for the display module, control buttons & encoder control!
Chris Williams
