I admire your optimism, but that's not what I was getting at.
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
With a little luck it will also mix the two red lasers for the 500 THz frequency difference.
Snowball's chance in hell. Just no way. But tell you what. If you bought that fiber + splitter at regular consumer prices at the magic emporium, and it does indeed do proper mixing in the fiber, I will buy said fiber by the truckload for double the price. What the hell, make it triple! People have to do actual work with temperature controlled lasers, gratings + control loops just to get lasers that enable that. And after that they have to expend actual effort in getting fiber optics with juuust the right properties. How likely is it that
"stick it in at an oblique angle" is a substitute for that?
You can even employ logic... What makes the Y-section different from a straight edge of fiber? What makes a photon more likely or less likely to mix in the y-section than a straight fiber stretch? Given these two hints, take the situation of a single laser A, laser B is off. With just laser A in a straight piece of fiber, or the magic y-section for that matter, why would those photons not suddenly selfmix in equivalent circumstances?
Because the photons of just laser A passing through the magic Y-section with "properties" have sufficiently different energies that if they were doing what you hope they were doing, then you'd also be able to see that (the selfmixing). And then you would heat/cool the laser, and check if the change in measured signal agrees with expectations for the selfmixing scenario.
The 10 MHz beat you are seeing is not photon-photon "mixing" interaction. What you are seeing is the equivalent of this setup:
- take photodiode
- divide it in left and right part (just for sake of argument, in reality people don't give a shit because same results no matter where you shine)
- laser A of some nominal wavelength, use 10 MHz signal to modulate laser A supply current, voltage, whatever really.
- laser B of some nominal wavelength, use another 10 MHz signal to modulate laser B supply current, voltage, whatever really.
- shine laser A on the left part of the photodiode
- shine laser B on the right part of the photodiode
Tadaaaaaa, "mixing". For suffiently correct use of the word mixing. In that setup you will indeed be able to see the beat frequency that is the difference between the two 10 MHz signals. But alas, no 500 THz mixer on the cheap.
Couple of random links:
https://en.wikipedia.org/wiki/Laser_linewidthhttps://en.wikipedia.org/wiki/Tunable_laser#Narrowband_tuninghttps://en.wikipedia.org/wiki/Four-wave_mixing#Applications_of_FWMgoogle this one: "laser diode external cavity wavelength", loads of articles related to one of the required ingredients.
or google this: "four-photon mixing fiber". Yes, your hoped for case would be two-photon mixing, but the info density is higher for the 4-photon google.
Anyways, I
hope that makes it clear what you are seeing. If not ...
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
that was my best shot.
