Stability and "Nixie" Clock are greyed out too
Looking at the debug log the EFC values are being queried and coming back with sensible values ok. Is there an obvious reason why these don't work other than the great difficulty in reverse engineering the original?
I am missing that information too. The reason seems to be, that the Symmetricom does not deliver the appropriate timing data and additionally always appends an unwanted "Command Complete" string to any command given.
I did also not succeed to put time/date date into the Symmetricom to speed up satellite aquisition.
GPS:INITial:DATE 2016,1,29 // does not work (legal syntax but no effect)
GPS:INITial:TIME 23:59:01 // does not work (legal syntax but no effect)
GPS:INITial:POSition N,+52,+etc,E,+13,+etc // works ok
Kutte
