The only thing about the Symmetricom is that when you do a power off on re-connect it will take 2hours to do a survey ,but the trimble remembers and saves its settings so when the trimble gets lock that's it going after mins not hours,
Dave
I have the feeling it is sometimes quicker. But sometimes not so. I'm poking my position into the unit, maybe if i use a fixed GPS antenna (on the to-do list) that would really work. According to another manual (58503B unit) poking position
and time/date should help to speed things up. I´ve tried it, but did not find an improvement. But maybe that´s because the gps antenna is not a fixed one. If more people could try
Unfortunately i won´t be able to easily load date/time with my acient pic solution. Could add an RTC chip but that also requires setting (and writing software to do so). Current status is that i have multiple reponse strings on the display and switching on a red LED in case the pll status is not saying PLL stabilized. The info is also on the display obviously, but a red LED will be much more visible.
When i get more time, i´ll continue with the button control for the output and it´s status LED and then some costmetics. It´s a slow process, i program in assembly (and i like it)
