To my knowledge these do not run the GPS or CPU clock from the OCXO. (It could, I just don’t know, and I don’t recall seeing it mentioned.) What’s interesting to me is that it reports 12 visible sats and tracking only one. So the GPS receiver is at least partially working. Did you notice the latitude/longitude puts you in Japan? (Your profile flag implies Brazil I think.)
You could try entering your current location with: GPS:POSition N or S,<deg>,<min>,<sec>,E or W,<deg>,<min>,<sec>,<height> - an approximate location is fine. Setting the location this way can make a big difference in startup.
You make no mention of the antenna, whether it’s confirmed to work with other GPS with 5v antenna feed, or the antenna location. The Furuno receiver is not known for it’s high sensitivity.
